Oil return
Discussion in 'Bonneville' started by mixifix, Jan 30, 2016.
  1. mixifix
    mixifix Active Member
    May 7, 2013
    108
    mansfield
    Seem to be a problem somewhere checked oil level twice now then when going on bike it stops then oil light comes on not sure if oil is returning quick enough or a slight blockage somewhere
  2. thebiglad
    Have you considered changing the oilfilter? There is a valve in the bottom of it and sometimes they go faulty. Put a Triumph branded one in then you'll know you've eliminated that as a cause.
