Oil In Water Or Water In Oil Possible Cause
Discussion in 'Technical Help' started by sti5300, Mar 26, 2020.
  1. sti5300
    sti5300 Well-Known Member
    Jan 22, 2020
    22
    58
    Swansea
    Whilst trying to route the 4 pipes behind the water pump on a 2009 and failing, I decided to remove the water pump to make it easier. I noticed that the rear seal on the pump was nearly out of it's seating. I'm new to Triumphs and not sure if this is a common issue but may hint at a possible cause for someone.
  2. Helmut Visor
    No clue I'm afraid mate but with a bit of luck a proper knowledgeable person will point you in the right direction ;);)
