Oil Capacity ?
Discussion in 'Speed Triple' started by Toad076, May 17, 2018.
  1. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    Essex .. Near Bas Vegas
    Ello all ... figured i'd better do an oil change on the old girl as she hasn't had one since I got her back. Book says .. dry engine/new filter .. 4 litres 10w/40 ... drained the old out ... filter swop etc all good ... stuck in 4 litres as stated ... cant see the oil level in the window ... but as I as disposing (legally) of the old oil I realised theres near on 7 litres come out ... am I missing something ? That's a big old difference
    She's a 2000 955i
  2. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    No its upright on an Abba stand .. but the amount that came out seems to be a lot more than has gone in .. im confuzzled
  3. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    Its sitting level .. engines been run for a few mins as per the manual .. been sitting for about an hour now .. im wondering if the book is wrong and the capacity is more than I thought
  4. Richard Neale
    Richard Neale Active Member
    Apr 20, 2018
    156
    Northwich
    Are you sure you put the drain plug back in before adding oil ?
    May explain the 7 litres !
  5. stevethegoolie
    stevethegoolie Elite Member
    Oct 16, 2014
    2,454
    East Riding of Yorkshire
    I had a 2002 Daytona 955i a few years back which had a dipstick to check the oil with. I guess something changed between '00 and '02. However, 4 litres will be plenty for an oil/filter change - unless that's changed as well!!:eek:
  6. capt
    capt Elite Member
    May 8, 2016
    3,050
    western Australia
    A 2000 955i should hold 4 to 4•5 litres , higher amount if filter done and bike was left to drain fully, almost all triumph variants between 92 and 2005 took 4 litres or so, Did you top up oils regularly ? As that could explain some of the 7 litres that came out , I never needed to top up my 94 trident or my 99 and 2000 Sprint's between oil changes/services.
  7. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    Aint nothing on the floor lol
  8. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    I don't have a dipstick .. just a viewing window ... but cant see the oil level at all
  9. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    It was topped up til visible in the window ... but obviously that's way more than 4 litres .. May have to enquire at a dealers
  10. Callumity
    3,358
    Are you measuring litres in and pints out? You should need a smidgen under 4 litres.
  11. Richard Neale
    Apr 20, 2018
    156
    Northwich
    How about in the drain pan with the other 3 litres ?
  12. Sprinter
    Is the window clean? 7l no.
  13. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    No lol .. went to put the "4 litres" of old oil in the now empty container ... filled to brim and still 2 litres left
  14. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    Nope afraid not lol ... all nicely tightened up and oil light out ...
  15. chuk
    chuk Senior Member
    349
    neilston glasgow
    something's far wrong there its overfilled bike if 7litres came out that's a definite,you say since you got it back ? Got back from where and when,if you had checked level previous what was level? In sight glass i assume that model is meant to have a sight glass ?,if it is meant to have one it must be halfway up glass surely an online manual is easy to download free.
  16. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    Is the engine standard?
    Maybe 4 ltrs has filled past the sight window and you're not used to seeing clean engine oil in there?
    Have you ridden the bike,... the only way I can imagine getting 7 ltrs in there is if some scrote nicked all the gears out your gearbox. :confused::joy:
  17. Ken walburn
    Ken walburn Noble Member
    Jun 28, 2017
    889
    Defo 100% should not have 7 litres in it. Even most big capacity diesel cars do t have a capacity as large as that
  18. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    I sold her back in 2005 ... found her again on e-bay so bought her back .. 8 owners since I sold her originally .. And yesthere is a sight glass .. but even with 4 litres in .. its not visible ...
  19. Ken walburn
    Jun 28, 2017
    889
    Chances are last service the mechanic renewed engine oil, was distracted, dragged off to assist a colleague, or tea break, then on his/her return filled the oil again. Not picked up coz sight glass no longer clear. Just a theory.
  20. Toad076
    Toad076 Member
    Jul 23, 2013
    32
    Every possibility .. unfortunately I don't know when the last service was .. tho going by the oil colour .. it wasn't recently
