Numb right hand HELP
Discussion in 'Speed Triple' started by gary1966, Aug 20, 2016.
  1. gary1966
    gary1966 Active Member
    Oct 5, 2013
    36
    suffolk
    2015 speed triple 94R I am really suffering with numb fingers/hand what can be done as its quiet bad can't feel a great deal not good when you can't feel the brake lever, I have changed the bar ends to add so weight I tried some foam covers that go over standard grips didn't like them as gave no feel on the throttle and it didn't help with numbness.
    I have a Daytona 675R and don't suffer with this numbness, when riding the speed triple it doesn't feel like there's any vibration, I have been riding for 30 yrs and have not suffered with this before, I don't grip the grips hard and grip the tank with my knees.
    If it was slight numbness I would just put up with it but this is not something I can put up with and it could be dangerous not being able to feel throttle/ brake lever.
  2. Dougie D
    Are you getting the numbness during a long run? i have found if i'm riding on a motorway for a long period i get numb fingers on the speed triple, i usually wear summer gloves so maybe a more padded glove would help
  3. gary1966
    Oct 5, 2013
    36
    suffolk
    It happens after about 10 minutes on the bike, I wear Knox Handroids but again there's no problem on the Daytona which that's the bike that you would think would cause problems, being upright didn't think this would happen
  4. roadrider
    roadrider First Class Member
    Jul 26, 2013
    1,003
    Oxon
    As it's only one side I'd suggest it's possibly more a grip issue than vibration,which would affect both hands.
    The same sort of thing came up on the Street forum a few years ago.I think the general consensus was that the throttle was so sensitive that people were gripping it to tightly.Though I don't thing the Speedy has a particularly sensitive throttle.
    Maybe bar risers might help?
  5. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    I think you'll find the bar risers are rubber bush mounted to the top yoke. Give them a check over, I've not dismantled so not sure whether there's a shoulder on the posts, may be over or under tightened?
  6. topbanana0
    topbanana0 Well-Known Member
    Mar 27, 2016
    226
    South Wales
    Used to get that on my ZX10, apparently it was a caricaturist of the bike.
    Not that this information help you.
  7. snarly
    snarly Active Member
    Sep 8, 2013
    52
    Gary, i suffered the same after about 10 mins riding my Speedy so put SW Motech risers on my speedy-i went for the taller of the two height options and it really helped. There's enough slack in cables to do this without any dramas
  8. gary1966
    Oct 5, 2013
    36
    suffolk
    I have ordered some sw motech risers fingers crossed these work
  9. Victor
    Victor Active Member
    Jul 26, 2015
    106
    North Wales
    Not suffered from vibration. But I lifted my bars up with 19mm spacers and it has vastly improved riding comfort. Best mod for less than a tenner.
  10. Tigcraft
    Your obviously trapping squashing a nerve. I sometimes get it on my left hand then I just lift my grip away and ride with my wrist just resting on the bars till the sensation goes away for a minute then back on. The answer is higher bars with less weight on them.
  11. desertspeedy
    desertspeedy Senior Member
    Jul 28, 2016
    436
    N. Phoenix, AZ, USA
    I too am suffering some throttle hand numbness. My speedy is a 2016 S so could a member tell me which diameter bars I have, please? Looking at the sw motech risers and need this information to order them.
    Thanks all,
    Chris
  12. gary1966
    Oct 5, 2013
    36
    suffolk
    But how come it doesn't happen on my Daytona 675R they are far from high bars
  13. Yorkshireman
    If you've got adjustable cuffs on the glove and or your jacket you could try slackening them off a bit, I sometimes get a bit of numbness if the glove is too tight.
  14. gary1966
    Oct 5, 2013
    36
    suffolk
    Same size gloves for years never been a problem before
  15. snarly
    Sep 8, 2013
    52
    Gary, you may find if your arms are quite straight on the Speedy which is aggravated when throttling then places your wrist in an uncomfortable position compared to your Daytona. I have an old Gpz900 which i don't have any problems with numbness despite the lower riding position but my arms are not so straight on this. Try moving the bars as well in the current set up to see if delays or increases numbness on set?
  16. thebiglad
    So no-one else saw the opportunity for a smutty remark to reply to this thread title then?
  17. Dougie D
    Don't think Wayne and Ade have seen this thread yet!
  18. thebiglad
    Me too - but for how much longer?
    98, 99 - change hands :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
    Oh bugger, that's torn it :oops:
  19. Victor
    Jul 26, 2015
    106
    North Wales
    In no way would I condone this whilst out riding and if you do, I take no responsibility for any criminal record received. But they do say that if you carry out a 5 finger shuffle (4 fingers and 1 thumb for the pedantic ones) with a numb hand feels like someone else is doing for you ;)
  20. darkman
    I had the same problem with my 16 and moved the bars back, worse. Moved them forward and far better :)
