Noise From Fuel Tank
Discussion in 'Technical Help' started by yeti007, Jun 8, 2020.
  1. yeti007
    yeti007 New Member
    Jun 8, 2020
    Switzerland
  2. Helmut Visor
    Hello Yeti, and welcome in :cool::cool:
  3. MadMrB
    MadMrB Elite Member
    Dec 24, 2018
    3,562
    Northamptonshire, UK
    Hi Peter and welcome in :)
    Sorry I can't help you with your noise... sounds like a helicopter to me :confused:
  4. yeti007
    yeti007 New Member
    Jun 8, 2020
    Switzerland
    Hi, yes the drive by wire motors are also clearly noticeable, but only if the engine is not running. It is more likely something from the fuel system.
  5. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Quite how you can tell anything from that sound clip.....cant really hear a whistling sound more like bad clutch rattle from a disengaged worn clutch to me.
  6. London_Day_600
    Jul 7, 2019
    41
    LONDON
    Welcome Peter,
    I can hear a 'whistling' which comes and goes lasting about 3 seconds - it occurs twice possibly 3 times in your recording.
    What makes you think it is the fuel tank? Have you had your ear up against it?
    Does it happen at higher rpm?
    I would first look around the airbox (debris inside/damaged filter) then check hoses connected to/from it.
    However as the bike is new and under warranty - once you pinpoint the source and are able to recreate it on demand/louder, I'd be taking it back to the dealer.
    Thanks.
  7. Tomap
    Tomap New Member
    Jul 5, 2020
    6
    Sverige
    Hello,
    As I said to another thread.
    My two weeks old t120 with 700 km just started buzzing from the throttle body...
    I have a the 800 km service booked on Wednesday and hope that will give a solution.
    Did you find a solution on your side ?
    Can't believe that kind of sound is normal... Especially when it just start from nowhere.
  8. Lou160487
    Lou160487 Senior Member
    Jun 16, 2020
    305
    163
    Florida U.S.A
    My 2019 Street Twin does the same thing. I think this may be normal. Along with the fuel gage taking over a mile to register full after a fill up.
