Sprint New engine and ABS question
Discussion in 'Sprint & Trophy' started by XT Bloke, May 23, 2016.
  1. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    Hi
    I need to source another engine for my '05 1050 Sprint, some are advertised as being from a bike with ABS, mine is non ABS, I can't think why an engine from an ABS model wouldn't fit my bike, can anyone confirm?
    thanks
  2. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    Hi XT,
    I needed help from Triumph last year and called their tech guys, I got straight through to them and they confirmed whatI needed to know.
    Not meaning to fob off your question, but I think this is one area that must be answered correctly otherwiseyou could buy an engine you can't use!
    It would be goodto be able to fit an ABS engine if it is younger and/or cheaper
    Contact Us
    There are a number of routes for contacting Triumph’s UK team, see below for which is right for you:
    For technical assistance or warranty:
    In the first instance we ask that you contact your Triumph-authorised dealer directly. If you have done this and your dealer has not been able to help you, please email [email protected], outlining the nature of the problem and quoting the last 6 digits of your motorcycle Vehicle Identification Number (VIN) (frame number) and the name of the dealer you have visited (we regret no action can be taken regarding warranty unless your motorcycle has been inspected by an authorised Triumph dealership).
    Please note this email is applicable to the UK and Ireland only. We regret we cannot assist with warranty queries for bikes registered overseas.
    For general enquiries you may wish to first visit our Frequently Asked Questions section. Alternatively customers in the UK and Ireland can call us on +44 (0) 1455 251700 or write to us at Triumph GB, Jacknell Road, Hinckley, Leicestershire, LE10 3BS.
  3. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    Thanks Red, called them up and was chatting to a tech within a minute - brilliant.
    The only difference is the speed sensor, on ABS models it is on the ABS wheel sensor, on non ABS it is on the gearbox and is simply fixed by removing the blanking plate and installing the sensor from the old engine.
    happy days.
  4. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    Bloody fantastic :)
    That is what you call a result.
    So you can find a 1,000 mile ABS engine for a couple of hundred and fit it quick with just a minor adjsutment.:D
  5. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    er yea summit like that, although that engine and that money would be excellent :)
  6. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    need to do some tests on the original engine first as I would hate to buy another motor and find it was elec failure for example.
  7. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    #7 XT Bloke, Jul 6, 2016
    Update, the old engine had a snapped cam chain and no compression, I have bought a 2007 engine which I fitted last weekend, had some challenges as the oil cooler and oil pipes changed between these years as did the lower fairing mount but I have managed to swap it all over.
    I sent the radiator away for a pressure test and it failed with 3 holes and not repairable so I have bought another from eBay.
    Need to put in some oil, coolant and fresh petrol and see if it starts....
  8. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    Update, new engine is running, needs a tune as doesn't always like to idle and sometimes coughs and stalls when revving from idle, got a VAGCOM cable and software coming tomorrow and hopefully that'll give me a clue to why and also why the ECU light is on.
    Took the old engine apart and found the cam chain hadn't snapped but had jumped off the cam shaft gears, not sure why, and the valves are bent.
  9. crispey
    Ouch! And double ouch!!
  10. steve lovatt
    Oh dear! :eek::eek:
  11. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    Update:
    The VAG-Com cable and TuneECU software showed 5 error codes, one was expected as the tank was removed, all the others said that various sensors had direct shorts to ground but one said the TPS Sensor was low on voltage, this got me thinking as there are 2 connectors that are identical and located right beside each other, one is the speedo sensor (if I remember right) and the other the TPS (Throttle Position Sensor), when I fitted the new engine I wasn't sure which was which, turned out I had them the wrong way around, once connected correctly the TPS gauge (TuneECU on my laptop) showed movement when I turned the throttle, hurray, all other error codes where then cleared and I hope they don't come back.
    I haven't managed to start it as the battery has finally packed up but this would explain the poor idle and rough running, new battery arriving tomorrow.
    VAG Com cable: http://www.ebay.co.uk/itm/301840068782 £9.95, dealer would have charged £100's to fault find and fix this issue so this is a no-brainer.
    TuneECU (software to use with the above cable) http://www.tuneecu.com/TuneECU_En/index.html
    Screen shot:
  12. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    #12 XT Bloke, Aug 7, 2016
    I expect this will be my last post on this thread as the bike is now done and took me to Norwich and back this weekend in record time (from Bedford).
    It went straight through the MOT last week.
    BMW Norwich open day.
    Still got a few bits to do, RHS fairing, rear pegs painting and fitting.
  13. thebiglad
    Excellent work Carter, well done - now ENJOY !!!!!
    PS About the cam chain jumping off the camshaft sprocket - it was possibly due to the chain tensioner lunching itself. Bits then get under the chain and 'prise' the chain off the sprocket.
  14. XT Bloke
    XT Bloke Member
    May 22, 2016
    12
    Bedford, England
    Yes, there were bits of tensioner in the bottom of the case and the sides were completely gone.
