New battery required
Discussion in 'Technical Help' started by ren, Mar 25, 2014.
  1. ren
    ren Member
    Jul 10, 2013
    9
    wigan
    HI,
    After leaving my bike with lights on for 2 hrs, it would not start, I then tried to bump start it, to no avail. I then got it started through jump leads on my dads car. since getting it home last night I put battery on charge, but it would not charge up, same thing tonight. Have I damaged my battery or something, as I have been told since that you shouldn't bump start or use jump leads off a car as it can blow the fuses, Can anyone help, as I was about to order a new battery.
    Thanks.
    Ren.
  2. SteveJ
    SteveJ Super Moderator
    Aug 12, 2013
    524
    North Hampshire
  3. ren
    ren Member
    Jul 10, 2013
    9
    wigan
    Thanks Steve j, I will get it sorted.
  4. Screwball
    Screwball Active Member
    Mar 21, 2013
    1,017
    36
    It may also be your charger. I have a halfords charger which won't charge a flat battery, it will only charge a battery with some charge in it. below a certain level it does nothing.
    However the optimate works on completly flat batteries, and i also assume some of the other inteligent chargers will also do this.
    Worst case as your battery drains it may have warped the inner cells in which case it is knackered..
  5. ren
    ren Member
    Jul 10, 2013
    9
    wigan
    Hi All,
    Just a quick update: I borrowed an intelligent battery charger and after 24hrs charge it stated fully charged, I will see how the bike goes. If it still loses charge then I will purchase a new heavy duty one. Thanks for your help.
  6. Screwball
    Mar 21, 2013
    1,017
    36
    Good result, hope it's ok..
    If it does not turn over then the battery is knackered.
