Trophy Need Fuel Pipe Help
Discussion in 'Sprint & Trophy' started by KIERAN ROB, Nov 17, 2020.
  1. KIERAN ROB
    KIERAN ROB New Member
    Nov 16, 2020
    #1 KIERAN ROB, Nov 17, 2020
    Hello again, after alot of problems getting my starter motor to turn, I did it, but now I'm abit confused to why its turning over but not fireing up, I have 6 pipes in total, a small one opposite side to the fuel tap, then I have 4 bigger ones coming from the carbs, and a small one coming from the carbs aswell, I only have two big holes on either side of the fuel tap and one small hole in the centre of the fuel tap, does anyone know witch ones go where and why I have two extra pipes coming off the carbs thanks.
  2. Peter B
    Peter B Active Member
    May 24, 2020
    206
    West Yorkshire
    Not sure about the system on the Trophy, a lot of fuel systems have a constant fuel flow and return, with the carbs/injection system taking fuel as needed.
