Maintenance Charging
Discussion in 'Technical Help' started by Spencer Rowley, Nov 20, 2018.
  1. Spencer Rowley
    Spencer Rowley New Member
    Nov 19, 2018
    12
    Nottingham
    Hi - I have a 2017 T120, about to store for winter. Now, a question about maintenance charging; I have an Optimate 4 charger, comes with two different types of attachment cables, one a crocodile-clip type, the other with O-ring type screw-on connector, I guess either one will work. Thing is though, do I disconnect the battery from the bike completely, or can I charge it with the batter connected??
    Thanks in advance guys!
  2. Spencer Rowley
    Nov 19, 2018
    12
    Nottingham
    Thanks mate, appreciate the quick answer.
  3. Spencer Rowley
    Nov 19, 2018
    12
    Nottingham
    Further question; the Optimate has 2 modes, STANDARD and CAN-BUS. I assume the CAN-BUS mode?
  4. Yorkshireman
    think I'll stick to torque wrenches
    Gawd elp us:p
  5. John B
    John B New Member
    Nov 10, 2018
    6
    Wirral
    I've twice attempted to fit my Oxford optimiser to my new Bobber but the in line fuse keeps blowing. I bought a new in line fuse cable but same thing. I attached the red clip to the live terminal and the black clip to the battery earth connected to the bike frame. appreciate some answers / advice. thanks guys
  6. John B
    John B New Member
    Nov 10, 2018
    6
    Wirral
  7. John B
    John B New Member
    Nov 10, 2018
    6
    Wirral
    New lead mate. As I said, connected red clip to red batt terminal and black clip to the earth strap connected to bike body. ( Not battery earth terminal) . never had this happen before, fitted to many previous bike
  8. Jeffrey Conlon
    Apr 4, 2018
    59
    Wakefield
    Think about it ! One plausible reason could be that IF the system is POSITIVE ground you are connecting the charger positive to the same point (frame) and shorting the charger out ?
    I presume that the charger fuse is blowing ?
    My best guess so far !
