Locking Fuel Cap Refusing To Lock.
Discussion in 'Bonneville' started by Neale McConnell, Aug 26, 2020.
  1. Neale McConnell
    Neale McConnell New Member
    Aug 26, 2020
    9
    Suffolk UK
    Anyone had trouble with their locking fuel cap. Both keys fit my 2018 T100 cap but they will not lock it. Any ideas other than getting a new one or leaving it unlocked?
  2. joe mc donald
    Neale McConnell
    Have you tried soaking the key with wd40 and leaving for a while. Other thing is to check its the same key to lock and the cap isn't one someone fitted and lost the key. But they are cheap enough to replace.
    Regards
  3. Neale McConnell
    Aug 26, 2020
    9
    Suffolk UK
    Thanks Joe I'll give that a try.
  4. joe mc donald
    Yes mate let it soak. Then fill the keyhole and gently wiggle the key a few times repeating the keyhole and wd. Wish you luck.
    Regards
  5. Alatamoc
    Alatamoc Senior Member
    Mar 29, 2019
    493
    Count your blessings.
    I had a series of Guzzi Californias.... all had the endearing habit of the key to the petrol cap key jamming in the lock when filling up with petrol.
    You'd be surprised how difficult that made things....the key also worked the ignition...so I couldn't close the tank or start the bike.
    Embarrassing.
  6. Neale McConnell
    Aug 26, 2020
    9
    Suffolk UK
    Hi folks Thanks for the advise and the welcome. After soaking overnight in WD40 the key is now turning freely and the cap is locking.
