Led Turn Signals
Discussion in 'Technical Help' started by Manimal, Jun 8, 2019.
  1. Manimal
    Manimal New Member
    Jun 8, 2019
    4
    Emerald Coast, Florida
    I have a 2011 T-Bird Storm. Can I use LED turn signals without any adaptors/Load Equalizer?
    I'm looking at the flat disk style with like 50 LEDS on it wired to a base, kinda of like Custom Dynamics.
    I was told to use the 1156 base & trim one of the base tangs/nubs off. Any help would be much appreciated.
    Thanks
  2. chuk
    chuk Senior Member
    349
    neilston glasgow
    I’m sure somebody will pass on better knowledge but I thought it’s not just plug and play,you need an adapter of some sort as they will work but won’t flash at correct rate not expensive as far as I know.
  3. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    They will only work correctly if you already have LED turn signal otherwise you will need an adapter.
  4. D'Ecosse
    D'Ecosse Senior Member
    Jun 23, 2019
    271
    CA, USA
    I haven't seen a schematic specifically for the Storm, but based on the Std T'Bird/1600/1700 schematic the turns are driven by the instrument panel - this is similar to the Rocket III Touring model i.e. there is no discrete turn signal module/relay that can be swapped out.
    The ONLY way to get the correct flash rate for that model is to add parallel load resistors - you only need two, one for each side and can be connected anywhere you choose between the supply line for each side, whether that be from or rear. You need a Resistor (per side) of 8-10 ohms and min 10W (or better) power rating.
