Featured Installed Usb Charger
Discussion in 'Speed Triple' started by Vulpes, Feb 2, 2019.
  1. Vulpes
    Because I wanted to be able to charge two devices, and did not want to hard-wire them I decided to put a dual USB charger in.
    Drilled a hole in the flyscreen.
    Put the charger in.
    Connected to switched wire in headlight assembly.
    Et voilà.
  2. TEZ 217
    Well done , your on a roll :eek::eek::eek::eek::eek::eek:
  3. Vulpes
    Might learn it yet, @TEZ 217 ! :D
  4. David Cooper
    Hi Vulpes
    I'm thinking about putting one on mine, but I'm worried about the waterproof quality.
  5. Vulpes
    Hi David, bit early to say - it has a cover for when not in use. Try to find a spot which is not susceptible to exposure.
  6. mpllineman
    mpllineman First Class Member
    Feb 12, 2018
    826
    Pearl,Ms.
    Looking good. Very clean job, and I like the looks of your port!
  7. Eldon
    Eldon Elite Member
    Looks good.
    Quick story;
    Manx GP 2017 I suggested to my mate it would be a good idea to put a usb on the handlebars for the phone's with being away for an extended period taking pics and vids. Mate said that's a good idea. We both fitted one but I didn't get round to using mine until there. Guess what, mine was faulty and wouldn't charge despite lighting up.
    He still takes the piss as I was beholden to him for the week :rolleyes:
  8. TEZ 217
    Good point Eldon,:) It should be tested and not assume all is well cos it lights up, :worried: I would imagine @Vulpes will be along shortly to confirm :cool::cool:
  9. Vulpes
    Yep, tested mine and all is well. Charges from both ports! :cool:
  10. Eldon
    Eldon Elite Member
    To add insult to injury I had bought a few different shaped items to see which fitted best...... and..... Yes you've guessed it, gave the others to him!!! :joy:
  11. Eldon
    Eldon Elite Member
    #11 Eldon, Feb 4, 2019
    I don't quite get why Triumph has put the usb under the seat on the 765. What you supposed to do, put your phone under there to charge it?
    I think a port on the handlebars is better especially if you have a tank bag fitted.
    On my Honda I put a usb socket under the back seat and it worked well with my phone in jacket pocket until a day or so later calling for petrol forgot the lead and ragged the end off. It was damned inconvenient as I was away for a week but at least the lead suffered and not the phone port.
