Immobiliser Draining Battery
Discussion in 'Technical Help' started by Daryl Bromley, May 3, 2020.
  1. Daryl Bromley
    Daryl Bromley New Member
    Dec 26, 2018
    15
    Shropshire
    Hi, Got a tiger 800 xrt 16 plate. The battery is flattening after 5 days and mechanic has traced it to the immobiliser, when he takes the fuse out the drain stops, any ideas why this is happening, could it be one of the relays which the fuse affects to the dash as has been suggested. Thanks in anticipation. Daryl.
  2. Gladtobebackontwowheels
    Nov 23, 2019
    398
    393
    Dover. UK
    The Daytona T595 / 955i always had problems with the alarm/immobiliser they just used to get taken off. I've not come across one that still had it fitted.
  3. crispey
    Yes the immobiliser does drain the battery, how old is the battery? It could be on its way out, it can be a long drawn out process. Best to consider a new one.
  4. Daryl Bromley
    Dec 26, 2018
    15
    Shropshire
    Its a brand new battery.
  5. Daryl Bromley
    Dec 26, 2018
    15
    Shropshire
    It is a new battery, fully checked, correct one.
  6. Gladtobebackontwowheels
    Nov 23, 2019
    398
    393
    Dover. UK
    If it takes 5 days to drain the battery just get an Optimate and keep it plugged in when it's parked up. The bike is never going to sit for 5 days unused outside of the garage so it will be fine. Or do you mean 5 days while being used? If that's the case it can't be charging properly.
  7. Daryl Bromley
    Dec 26, 2018
    15
    Shropshire
  8. Daryl Bromley
    Dec 26, 2018
    15
    Shropshire
    5 days if not used, we were coming to the conclusion to use a optimate, finding what is draining the battery could be a long and expensive option, thanks a lot for your help and advice. Daryl.
  9. crispey
    Ah!
  10. crispey
    You haven’t got any unknown electrics connected or connectors earthing under the seat maybe? Things for heated stuff or satnavs, tracker?
    Edit* most trackers have their own power source but you never know
  11. Daryl Bromley
    Dec 26, 2018
    15
    Shropshire
    I think it's all sorted, someone walked into workshop and while talki ng to James about my bike noticed a light blinking under topbox plate, turns out a datatool tracker had been fitted which I didn't know about, and was drawing a constant 4ma, perhaps the battery in it was dead so was constantly trying to charge up. Tracker now disconnected so hopefully problem solved. Thanks for the help peeps.
    Daryl
  12. Daryl Bromley
    Dec 26, 2018
    15
    Shropshire
    Daryl
