Idle Transition Knock and Noise
Discussion in 'Technical Help' started by MadDanEccles, Apr 15, 2013.
  1. MadDanEccles
    MadDanEccles New Member
    Apr 13, 2013
    2
    Hi, I've got a 2004 Daytona 955i with 13,000 miles on the clock. It's developed noise at idle (a 'slight rattle' would be a good description); when the engine speed rises to to about 1700 rpm it emits one noticeable 'tap/knock' (akin to a ping-pong ball hitting a table), which can be easily heard and just felt through the bars, and the idle noise disappears; when the engine slows there is another 'tap/knock' at the same engine speed and the idle noise returns.
    This occurs whether in neutral or in gear (both applying power and engine braking) and when the clutch is engaged or disengaged. I think, therefore, that the noise is purely a function of engine speed and not of torque or power.
    My local triumph dealer were concerned about this during a recent service, but were unable to offer any suggestions as to the cause and, try as I might, I've only found one other person that's had the same problem but they didn't post the solution.
    It has been suggested on another forum that it may be worn clutch tangs or final drive, which I will investigate, but if anyone has any other ideas I would be really grateful!
    Many Thanks.
  2. Screwball
    Screwball Active Member
    Mar 21, 2013
    1,017
    36
    I would guess cam chain or clutch.... And that is a guess without hearing the noise.....
  3. Richard H
    Richard H Noble Member
    Oct 26, 2012
    1,132
    Am amazed your local Triumph dealer could not at least give you an idea as to the cause I should try another dealer and see if they are more help. You could try uploading a sound clip to the thread..... May get a few more answers.
  4. jonny
    jonny Active Member
    Mar 26, 2013
    142
    sunny cheshire
    cam chain would of been my first thought..
  5. Screwball
    Mar 21, 2013
    1,017
    36
    Jonny. Great minds an all that.....
  6. MadDanEccles
    Apr 13, 2013
    2
    Thank you :) I've got her booked in to the garage to have the cam chain and tensioner checked and replaced if required - hopefully that should solve it and if not then I've got a few other avenues to investigate.
  7. jonny
    jonny Active Member
    Mar 26, 2013
    142
    sunny cheshire
    keep us informed of how you get on :upyeah:
  8. MadDanEccles
    Apr 13, 2013
    2
    The garage have checked the cam chain and tensioner and found nothing wrong ... The investigation continues ...
  9. Screwball
    Mar 21, 2013
    1,017
    36
    But did they have an opinion on what it could be?
  10. MadDanEccles
    Apr 13, 2013
    2
    #10 MadDanEccles, May 13, 2013
    Right - got a second opinion from another Triumph technician -Apparently the engine noise at idle not out of the ordinary for a 955i. It turns out that there is a solenoid controlled air valve under the tank (Not being a Triumph expert I can only assume this is SAI) - at 2000rpm (give or take) this valve operates which causes a knock along with the change in engine tone - again this is normal (and more noticeable on some engines than others).
    Why on earth the original garage didn't mention this as a possibility (and saved a lot of hassle) I don't know - I even asked the guy about the possibility of it being an EGR valve or similar and he said that no such valve was fitted to a 955i! At least I have peace of mind now but I will most certainly be using a different garage in future.
    Thank you everyone for your support and suggestions - I shall now try to track down the other post I found regarding these symptoms and reply!
