Help! Tiger Sport 1050 2014 - Difficulties Starting
Discussion in 'Technical Help' started by FarmerLee, Dec 29, 2019.
  1. FarmerLee
    FarmerLee New Member
    Dec 29, 2019
    Gloucestershire
    Hi,
    I bought the bike earlier this year. It's been running fine until recently. I went to start it up last week, it started fine but after a few minutes it cut itself off. Since then, all that seems to happen is the dash board lights up. The lights and alarm works however the fuel guage does not register and there is no fuel injector sound. I have managed to start it up once for a few seconds and then it stopped.
    I have checked all the fuses. I've tried another battery and tried jumping it from another bike but still no joy. I've topped up the fuel.
    Any help would be appreciated.
  2. Callumity
    3,358
    TuneECU is free diagnostic and tuning software. Instead of chasing shadows you might buy the cable needed to hook up to your device and see what error codes appear.
    https://tuneecu.net/TuneECU_En/index.html
    It could simply be a dead sensor.
  3. Helmut Visor
    Hi Lee, and welcome in :cool::cool:
  4. joe mc donald
    FarmerLee
    Welcome to the family. Yes also check all the connections around the battery an cut out switch's. Quite difficult to think it out not seeing it. Do let us see the steed by hitting the upload a file button.
    Regards
  5. RicoP
    RicoP New Member
    Aug 2, 2020
    2
    Hi. Ive just bought a 1050 sport 2018 and found occasionally it the starter button was dead. After fitting a new battery[ which didnt sort the problem] I had all the connections between the battery and starting motor checked and found a loose earth and some poor connections . These were remedied, and just to make sure fitted a new starter relay. In the last 2000 miles ive not had any problems at all. Hope this helps
