Help I’ve Lost The End Of Syphon In Fuel Tank
Discussion in 'Triumph General Discussion' started by timboo, Oct 16, 2023.
  1. timboo
    timboo Senior Member
    Oct 17, 2021
    295
    Cambridgeshire
    #1 timboo, Oct 16, 2023
    As the title suggests I’ve royally screwed up. I decided to remove some of the fuel in prep for winter and the end of my syphon has come off inside my tank. Is there an easy way if getting to it?
    Annoyingly it worked a trick last year unfortunately got snagged this time.
    Is it case of fuel tank off?
    Its a thruxton R
  2. Dawsy
    Dawsy Cumbrian half-wit
    4,922
    Cumbria
    What is it made of? Can you get a flexible magnet in there?
  3. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    #3 timboo, Oct 16, 2023
    Copper I think :-(
    I’m hazarding a guess i need to remove the tank and the fuel pump to gain better access. I dont own an endoscope and nice pair of small pincers to grab the damn thing unfortunately.
  4. Carl556
    Carl556 Senior Member
    Nov 13, 2019
    260
    Durham Uk
  5. timboo
    Oct 17, 2021
    295
    Cambridgeshire
  6. Carl556
    Nov 13, 2019
    260
    Durham Uk
    Perhaps easier to just lift the tank then. Not too hard a job if you give yourself plenty of time, a workshop manual and a decent supply of tea and biscuits :)
  7. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    I will give triumph parts a bell tomoz to see if i need to replace the gasket if i remove the fuel pump.
  8. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    Yep tank off I reckon I have searched the forum for tank removal and the worst part seems to be the fuel line clip at the tank from what I can see.
  9. FezUSA
    FezUSA Member
    Sep 1, 2023
    38
    OH, USA
  10. Marco Wikstrom
    Sep 28, 2023
    81
    Albuquerque, New Mexico
    #10 Marco Wikstrom, Oct 17, 2023
    It shouldn't be too difficult to siphon most of the fuel, remove the tank, invert it and shake it over an oil change tray until the siphon head comes out. Might have to remove the gas cap assembly if it gets in the way.
    To siphon fuel I use a 1-1/2 ft straight aluminum pipe attached to some clear hose - nothing to fall off.
    In my experience to store for winter I keep the gas tank full so there's less chance of condensation building up inside the tank. An empty cold tank will build up condensation causing rust and/or water in the fuel system. Add a little fuel preservative before riding to the gas station, and then more after the tank is full. This way the fuel preservative has a chance to work its way into the injector system.
  11. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    cheers didnt know that re full tank. I realised that I used 2 hoses last year one to blow the other for the fuel to leave. I now remember removing the end for that very reason
  12. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    Lesson learnt managed to fish the culprit out following removal of the fuel pump, for once a gasket could be re used. Double checked with Triumph as thought it looked more substantial than others.
    Good to learn more about my bike.
  13. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,439
    Go fishing with one of these pick up tools.
  14. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    I’m glad i didn’t use one of those having removed the fuel pump and found that there are delicate wires inside the fuel tank.
  15. Col_C
    Aug 5, 2015
    1,439
    Yeah, they can be a bit sharp.
  16. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    Amazing pieces of kit these motorcycles are
  17. andypandy
    I've got a 71 cb250 and I was cleaning the tank out a few years ago, the bike hadn't run for over twenty years. I was a bit surprised to flush out half a hacksaw blade. How the heck did that get in there ? :eek:
  18. jackyma09
    jackyma09 Member
    Aug 10, 2023
    22
    New York, USA
    That's a tough situation. It might be necessary to remove the fuel tank to get to the stuck piece. I recommend checking with a mechanic or consulting the Thruxton R's guidelines for the best way to handle it.
  19. timboo
    Oct 17, 2021
    295
    Cambridgeshire
    Cheers I ended up removing the tank and fuel pump then fishing it out in the end. Wont be doing that in a hurry again.
    Images posted several months back thanks anyway.
  20. RickM46
    RickM46 Active Member
    Oct 12, 2023
    46
    US
    Is there a step by step for tank removal or a link that you found for tank removal?
