675 Help Guys Part Numbers Required
Discussion in 'Street Triple' started by Lee poulter, Aug 5, 2020.
  1. Lee poulter
    Lee poulter New Member
    Aug 4, 2020
    Leeds
    Hi guys anyone got a exploded parts list for street triple r 06-10
    I need the front sprocket, washer and nut.
    lost all drive on Monday night but after stripping found the nut too of come loose. Might aswell changed the sprocket now I have it open
    Cheers
    lee
  2. Samsgrandad
    Samsgrandad Senior Member
    Dec 15, 2019
    552
    Somerset
    Look on www.worldoftriumph.co.uk you will find a parts diagram and prices of the relevant bits
  3. Octoberon
    Octoberon Crème de la Crème
    Jul 2, 2020
    2,250
    Peak District, Yorkshire
    That's a useful looking site, thanks. Hadn't come across it before. A bit confusing the VIN ranges are defined compared to what's on my V5C but I'll figure it out.
  4. MadMrB
    MadMrB Elite Member
    Dec 24, 2018
    3,562
    Northamptonshire, UK
    If you find parts you want, use the OEM part number search on Fowlers https://www.fowlersparts.co.uk/ and/or Wemoto https://www.wemoto.com/ - who are both usually cheaper. Fowlers don't carry any where near as much stock as World of Triumph, and neither do Wemoto, but in my experience Wemoto order in parts and deliver to you very quickly.
  5. Eldon
    Eldon Elite Member
    I had this happen on a Yamaha 600 thindercat. I blamed it on hard downchanges reversing the thrust.
    Strangely I found the tab washer still bent over in the chain crud behind the casing but the nut had long gone.
    Loctite the new nut on.
