Fuel Tap Suck
Discussion in 'Technical Help' started by Triumphant Tony, May 6, 2023.
  1. Triumphant Tony
    Triumphant Tony Active Member
    Jan 30, 2023
    70
    Western North Carolina
    When putting my bike back together I noted that the vacuum line to the fuel tap fit pretty loosely. After running around beautifully for a few miles the bike stalled and would only run if the fuel tap is set to prime. I was about to order a rebuild kit, but it occurred to me that the problem might be that loose vacuum line. So my question is.... Could a loose or possible fallen off vacuum line cause the tap to not function and starve the carbs of fuel?
    1995 Trophy 900
  2. Pegscraper
    Pegscraper Elite Member
    Jun 12, 2020
    3,427
    In a word, yes. Vacuum operated fuel taps became quite common back in the good old pre-EFI carb days. A leaky vacuum line could also lean out the fuelling, potentially affecting engine idle.
  3. Triumphant Tony
    Jan 30, 2023
    70
    Excellent point about leaky vacuum line. Doh! Must have fried my brain yesterday.
  4. sprintdave
    1,621
    Also check you haven't kinked the fuel pipe as it can cause a blockage, easy done. Yep I have been there.
    • Disagree Disagree x 1
