Front Forks Ohlins Zero Position
Discussion in 'Technical Help' started by 6Foot6Dude, Jun 8, 2022.
  1. 6Foot6Dude
    6Foot6Dude New Member
    Jun 8, 2022
    Turkey
    I seem to have trouble finding the "zero position" for both the compression and rebound adjustments. As far as I know I have turn them all the way in and count the clicks unwinding them. I seem to have overtightened the compression one because it started to turn the preload adjuster, then I unwinded it scared of having damaged it. It still clicks etc.
    1. Do you think I have damaged the adjuster or any internal components?
    2. How can I find the zero position properly?
    I am also scared of stripping the bolt head since it seems to be made of a soft material, and any tips to prevent that would be greatly appreciated.
    Thanks
    Edit: The bike is a 2020 Speed Triple RS 1050
  2. Wessa
    Never liked to play with my suspension. For me I would recommend taking your bike to a specialist. Might cost, but you can be confident it is set up correctly for you.
  3. Linx
    Linx Well-Known Member
    Mar 14, 2020
    198
    Stratford Upon Avon, UK
    Sounds like you did over tighten it. It should be obvious when the adjusters bottom out. Don't use any force. All the way clockwise is position zero. You could have damaged the bottom of the rod a bit but I wouldn't worry about it. Will probably still work fine. The bottom of the adjustor rods have a point on the end that fits into a small holes on the bottom of the damper unit. Rod deep into hole restricts oil flow. Screw it out and it allows more oil flow.
  4. SpeedTwin1200
    SpeedTwin1200 Senior Member
    Jul 21, 2019
    261
    Hampshire
    As Linx said, the adjusters don't need any force. Watch at around 5.00s, he uses his finger tips to turn the allen key....
  5. SpeedTwin1200
    Jul 21, 2019
    261
    Hampshire
  6. Linx
    Mar 14, 2020
    198
  7. 6Foot6Dude
    Jun 8, 2022
    Turkey
    Is it also possible that I coul have damaged the holes that the needle goes into?
    I hope I have not damaged anything.
  8. Linx
    Mar 14, 2020
    198
    Unlikely. The adjuster rods are aluminum. I think the whole damper cartridge is steel.
  9. 6Foot6Dude
    Jun 8, 2022
    Turkey
    Thank you :)
  10. 6Foot6Dude
    Jun 8, 2022
    Turkey
    #10 6Foot6Dude, Jun 12, 2022
    There seem to be clicks even after I encounter some resistance. I just went to check if the suspension is still functional and if there is any difference in compression resistance in between different positions of the adjuster but I can not seen to tell if there is any. Am I being paranoid? It seems unlikely that the needle is detached from the or something since I feel resistance thorugh the adjuster at the upper most and lower most settings.
  11. SpeedTwin1200
    Jul 21, 2019
    261
    Hampshire
    I think that this video should answer your question. You're not paranoid, you know it's not right. This I think is what has happened....
  12. SpeedTwin1200
    Jul 21, 2019
    261
    Hampshire
    I've just seen the comments! Looks like you've found this clip already. He says it is broken but can be fixed with a fork rebuild. I think this will be your course of action. Good luck.
  13. 6Foot6Dude
    Jun 8, 2022
    Turkey
    Hahha you must have seen the video comments. By the way, is it possible tp induce this kind of damage to the rear shock, where the adjsutöents are made bu turning a wheel? It does not feel like it will since it has hard-stop.
