Final Drive Hub Nut, Replace Or Reuse?
Discussion in 'Technical Help' started by topbanana0, Oct 28, 2018.
  1. topbanana0
    topbanana0 Well-Known Member
    Mar 27, 2016
    226
    South Wales
    looking to service my rear wheel bearings, the staked nut (left side) is recommended to be replaced.
    But a new one is almost £20. They don't recommend replacing the rear wheel nut.
    Both are on the same axle, under the same stress (I would have thought)
    The manual I've read also recommends replacing the rear brake calliper to hanger bolts (£7 each)
    Seams a bit ott
  2. t552
    t552 Senior Member
    Nov 17, 2014
    416
    Bristol UK
    I'd only replace if damaged
  3. Yorkshireman
    Agree, bit of thread lock on the caliper bolts maybe, don’t see the need to change them.
  4. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    The only nuts/bolts i renew are con-rod ones, everything else gets reused or replaced with stainless.....unless the belong to a Japanese car and are small they are all made of cheese so get thrown away.
  5. Callumity
    3,358
    The issue with staked nuts is losing the stake on disassembly and having no means to re-secure - loosening not strength. On clean threads I would happily use normal thread locker like Loctite and a dab of nail varnish as a telltale of any movement. Choose your colour with care!
  6. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    I have reused them with no problem, its also unlikely that the peaned section will re align on re tightening so its just a case of re peaning, but i would also quite happily use a decent thread lock , staked nuts are normally used on things like car hub nuts where they are hidden or fit and forget for the added security, but unless its a high load situation i wouldn't worry.
