Engine management
Discussion in 'Technical Help' started by Jockstew, Apr 30, 2016.
  1. Jockstew
    Jockstew Active Member
    Apr 30, 2016
    142
    Bridge of Weir Scotland
    Engine management light came on today after IAM Slomo training day ,there seems to be plenty of oil and bike is running well.was told it will reset itself after a while any thoughts
  2. thebiglad
    There is a built-in process for the engine light, assuming the fault is not continuing.
    After 3 complete cold/hot/cold cycles, the light will go out.
    What year is your bike Jock. Mine was a 2010 T100EFi and I used a cable and a free-to-download program called TuneECU which gives access to the bikes ECU for tuning and error-checking purposes.
    Useful linky: http://www.triumphtwinpower.com/ttp-obd-2-usb-cable.php
  3. Thruccyboy
    Thruccyboy Senior Member
    Nov 18, 2015
    458
    Tis true, mine went on when I forgot to attach one of the breather pipes under the tank & as thebiglad states, after 3 cycles it resets itself.
  4. Jockstew
    Apr 30, 2016
    142
    Thanks
    Big guy & Truccyboy guess time will tell ,also a 2010 but just basic 865 Bonnie
    Read your post on Scott oilers and gas suspension will think about both
  5. Jockstew
    Apr 30, 2016
    142
    Light out ,bike going fine reset after three cycles cheers
