Feel fairly sure it is but wanted to ask 'just in case'. Is the electrical system on a 2023 T120 up to powering heated gear without over-loading it? starting to get a bit chilly here in 'The Heart of Dixie' Talking about only a heated jacket liner.
There is a connection for heated grips that you could tap into or purchase the auxiliary plug to plug your items into A9828050 | Auxiliary Power Socket
Tks but I have it set-up to use the Batt Tender plug directly to the battery. Had the heated grips added before delivery. Question is will the charging system be over-taxed using both at the same time?
Will be fine if separate circuits. Most guys here use the auxiliary/battery tender plug for heating/lights/phone chargers when riding and then unplug for the tender to charge when not in use
