Electrical Help For A Bag Of Nerves
Discussion in 'Vintage Classics' started by chiari1, Apr 26, 2020.
  1. chiari1
    chiari1 Elite Member
    Mar 19, 2016
    108
    wrexham , north wales
    #1 chiari1, Apr 26, 2020
    x
  2. SprinterII
    SprinterII Noble Member
    Mar 27, 2020
    642
    Scotland
    #2 SprinterII, Apr 26, 2020
    so you are installing a up grade to the ignition that comes with a regulator /rectifier. Do you have a link to the product?
    The regulator rectifier is a combined unit. It does the rectifying part as well the regulation part.
    It is part of a battery charging system.
    It usually gets an AC power feed from the stator coil of the generator (alternator).
    Most modern regulator rectifiers and Stators form a three phase system, so there are three wires coming from the stator feeding into the regulator rectifier.
    The regulator rectifier then rectifies the voltage; that is it turns the voltage from AC into an undulating DC.
    The voltage is then regulated; the voltage being limited to a maximum of about 14.5 volts and feeds this regulated DC out to the battery.
    There are some single phase, regulator rectifiers as well which perform a similar function but there are only two wires coming from the stator into the regulator rectifier which is then fed to the battery in the same way as the three phase system. Why are there two different systems? Three phase is more efficient and single phase are cheaper to produce.
  3. Rocker
    Rocker Elite Member
    May 1, 2016
    1,662
    Suffolk
    you should have been given a diagram with the new part just follow that
  4. SprinterII
    Mar 27, 2020
    642
    Scotland
  5. SprinterII
    Mar 27, 2020
    642
    Scotland
    Is it single phase?
    Which model?
  6. SprinterII
    Mar 27, 2020
    642
    Scotland
    Is it a 6 volt to 12 volt conversion?
  7. EJT
    EJT New Member
    Nov 23, 2019
    12
    Michigan US
    Don't think you can get there from here with the Pod. Looks to be 12v only. You'll have to convert your system to 12v for everything to work. (Lights& batt). Electronic ign also if 12v.
  8. SprinterII
    Mar 27, 2020
    642
    Scotland
    so this is you," lf you have an early bike with 6 volt, three wire alternator, 47204 or 47194, this can be converted to 12 volts" ??
  9. SprinterII
    Mar 27, 2020
    642
    Scotland
    Are you trying to fit an ignition upgrade too?
  10. EJT
    EJT New Member
    Nov 23, 2019
    12
    Michigan US
    According to the Podtronics sheet, yes.
  11. SprinterII
    Mar 27, 2020
    642
    Scotland
    Ok so if your purple wire is their brown +white wire, and everything else is the same, and you've traced the purple and it goes straight to the battery positive with no off shoots.
    Then your good eh?
  12. EJT
    EJT New Member
    Nov 23, 2019
    12
    Michigan US
    According to my parts book a 1958 T20 or T20c uses a 468678 stator. Not a 47204 or 47194 stator mentioned in the Pod sheet. No apples to apples here. I would contact Podtronics and see what they have to say.
  13. Rocker
    Rocker Elite Member
    May 1, 2016
    1,662
    Suffolk
    Doesn't the electronic ignition need 12 volts?
  14. SprinterII
    Mar 27, 2020
    642
    Scotland
    Does your rec look like the "old one" in the instructions?
  15. SprinterII
    Mar 27, 2020
    642
    Scotland
    Right so
    You have 3 versions.
    1/ what you have
    yellow, to alt.
    yellow , to alt
    black , to ? ( is it ammeter if you have one then battery -)
    red, to ? (is it battery + then earth)
    2/ Old wire dia.
    dark green to Alt
    light green to Alt
    purple to 13
    3. what the instructions say you have
    white green to Alt
    green black to alt
    red to battery + and earth
    brown white to Ammeter ( if fitted) then Battery -.
    Where do your red and black go?
  16. SprinterII
    Mar 27, 2020
    642
    Scotland
    Any progress?
