Tiger 1050 Disconnecting/reconnecting Battery
Discussion in 'Tiger / Explorer' started by bulldogbobby, Apr 7, 2019.
  1. bulldogbobby
    bulldogbobby Well-Known Member
    Apr 1, 2017
    65
    norfolk
    OK So there's no such thing as a stupid question...……………..
    I'm about to fit a hard-wired charging/optimising plug to the 2016 TS and was just going to disconnect/reconnect the battery to do it. Seen different comments re warning lights and 3 x Hot/Cold cycles etc but will this cause any issues apart from resetting the clock? Is it an idea to jump lead from another battery?
    You know what they say, if in doubt - ask! ………….
  2. thebiglad
    Disconnect & reconnect a battery should present no problems at all. Just don't short across the terminals !!
  3. Tiglet
    Correct mate there’s no such thing is a stupid question when you don’t know the answer.
    Better safe than sorry.
  4. Fourbears
    Fourbears Noble Member
    Dec 8, 2017
    498
    413
    Norfolk
    What DD said. That's how I did mine!
  5. alfie
    370
    213
    Bath, Zumerset
    Disconnect the Negative Earth lead first (Black Lead) followed by the Positive power lead second (Red Lead)
    When reconnecting connect the Positive (Red Lead) first followed by the Negative (Black) lead.
  6. bulldogbobby
    Apr 1, 2017
    65
    norfolk
    All done with no dramas! Thanks for your help all
  7. Tiglet
    Now that wasn’t to bad was it :):)
  8. bulldogbobby
    Apr 1, 2017
    65
    norfolk
    Not at all - better safe than sorry tho eh
Similar Threads - Disconnecting reconnecting Battery
  1. spike
    22
    5,395
