Daytona 955i Fuel Lines
Discussion in 'Technical Help' started by Uncorrugated, Jun 20, 2020.
  1. Uncorrugated
    Uncorrugated Senior Member
    May 25, 2017
    543
    143
    Northamptonshire
    I recently had the tank off my 2004 D955i (and ebverything else off too whilst the engine was out) and stupidly didn't mark up which way round the fuel lines were attached.
    I know the bottom is the feed and upper is the return, does it matter which way round they are attached?
    It will run whichever way they are attached.
    Thanks.
  2. freck
    freck Elite Member
    May 4, 2017
    1,718
    Preston, Lancs, UK
    It doesn’t really matter as they just feed a straight through fuel rail, but if you’ve got the Triumph fit metal fuel line fittings like mine then the red one is the feed which should go to the r/h side of the rail (looking as you’re sat on the bike)
  3. Uncorrugated
    May 25, 2017
    543
    143
    Northamptonshire
    Thank you - yes it does have a red metal connector on one. I'll check which way round I have them in the morning.
  4. Gladtobebackontwowheels
    Nov 23, 2019
    398
    393
    Dover. UK
    I've fitted them both ways on purpose and it makes zero difference.
  5. Uncorrugated
    May 25, 2017
    543
    143
    Northamptonshire
    Runs a treat.
    Just a shame the fecker ticks over at 3000 rpm....:mad:
  6. freck
    freck Elite Member
    May 4, 2017
    1,718
    Preston, Lancs, UK
    Bummer! :p
    Hope you get it sorted mate. :)
  7. Gladtobebackontwowheels
    Nov 23, 2019
    398
    393
    Dover. UK
    I take it you've balanced the throttle bodies?
    Reset the TPS?
    Do you have TuneECU ?
  8. Uncorrugated
    May 25, 2017
    543
    143
    Northamptonshire
    TuneECU and OBD lead on its way. Checked breathers not kinked or blocked. Checked hoses to stepper motor ok (new), so will see what TuneECU has to say when lead arrives. :)
    However, I have ridden it up and down the lane at the back and the rebuilt gearbox is smooth and precise. Right chuffed with my efforts on that one!
