Charging Issue On A 2001 Legend Tt
Discussion in 'Technical Help' started by underground-mpyre, Jul 19, 2018.
  1. underground-mpyre
    underground-mpyre New Member
    Indianapolis
    Hello, new here. Nice to meet you all.
    So I was riding my bike last month and my bike died while riding and thought it was either the old battery or the alternator.
    I am frustrated with a charging issue on my 2001 Legend TT. I have tested the alternator professionally( in working order) and even bought a used one in good condition too. Brand new battery too. But I cannot get it higher than 12.3 DCV on charging the battery running. Should be 13.8 right while running to charge the battery?
    So thoughts?
    #1
  2. Sprinter
  3. underground-mpyre
    Indianapolis
    Ok, where is the R/R on this bike?
    It has an actual alternator and doesn't need one since it is a triple.
    #3
  4. underground-mpyre
    Indianapolis
    I am very familiar with what a R/R looks like. I have a Cbr and a Yamaha's with them. But this has an actual alternator , not stator unfortunately.
    #4
  5. Sprinter
    The alternator voltage is typically below the battery voltage at low rpms on these bikes and won't charge the battery until someplace around 2500 rpm. That's why Triumph specs the alternator at 14.5V at 5500 rpm.
    Your battery voltage should be 13.2V with the ignition off and you'll have a slightly lower voltage at an idle.
    Roll up the idle slowly while monitoring the battery voltage and it should increase to 13.5 or more by 3000 rpm.
    ALSO, wire brush your battery terminals and cable ends until shiny, coat with hi-temp wheel bearing grease and reassemble!
    A dirty/oxidized terminal will cause a resistive voltage drop that increases with current, so the harder the alternator tries to charge (higher voltage) the more the voltage will drop before reaching the battery.
    A defective battery with excessive internal resistance will cause the same problem as dirty terminals -- but you can't fix it.
    #5
  6. Oldyam
    Oldyam Grumpy Old Git
    ireland
    The R/R is built into the back of the alternator on your TT and there are a few connectors between the alternator and the battery that could do with checking and cleaning, you will need to follow the wiring from the alternator to the first connector ( a double ) where the alternator wiring connects to the main loom
    Your R/R is here
    http://www.worldoftriumph.com/trium...r?block_01=&block_02=302234-3-2&block_03=9412 Item 16
    #6
  7. Oldyam
    ireland
    Had another look, your TT feeds from the alternator via the fuseblock, I would check all the fuses and connections are clean and in good condition, replace the fuses if in doubt.
    As well as the earth connection from alternator case to chassis or battery negative whichever it is.
    #7
