Bonnie Problem
Discussion in 'Bonneville' started by Bonnie2014, May 20, 2018.
  1. Bonnie2014
    Bonnie2014 Well-Known Member
    Aug 25, 2014
    39
    After the winter lay off , I fitted a new battery. After one ride and a 2 week lay off , the battery was flat , recharged the battery , and when I put back on the bike , it doesnt start ? when I turn the key on , I get the headlight come on , but the bike doesnt do its thing where the clocks start up ! , and there is nothing when I press the starter ! any Ideas ? Its 1 2014 865 cast wheel bonnie
    Thanks in advance
    shaun
  2. Sprinter
    Have you got a multimeter?
  3. Bonnie2014
    Aug 25, 2014
    39
    yes
  4. Angus
    Angus Noble Member
    Mar 19, 2017
    935
    South Africa
    Does it have the switch on the side stand ? I've had it where sometimes it does the same on my speed triple, then I kick the side stand back out and back in then it does the pre check on the dash indicating that it's ready to fire up. It's almost as if the switch on the side stand is not registering that it's up. That and the run switch by the handle bar that you use to start. That's if you are sure the battery is fine which sounds like it is if the light comes on strong.
  5. Bonnie2014
    Aug 25, 2014
    39
    Ok , cheers , will check the side stand , never thought of that !
  6. Bonnie2014
    Aug 25, 2014
    39
    Ok , all up and running again , turned out to be a fuse ! I think to do with the auxilliary input that I run an Oxford Solarieser off .....must have been a sunny surge !
