Bonnie America Intermittent Battery Flat
Discussion in 'Technical Help' started by bob cope, Oct 10, 2017.
  1. bob cope
    bob cope New Member
    brereton staffs
    hi i've got a 2009 america with intermittent battery going flat the battery is under a year old can anyone help
    thanks bob
    #1
  2. bob cope
    bob cope New Member
    brereton staffs
    the battery is under 12 months old there is no alarm or heated grips fitted the only non standard bits fitted are a set of spot lights which go off with the ignition and pos and neg terminals to the battery for my oxford oximiser any ideas thanks
    #2
  3. Oldyam
    Oldyam Grumpy Old Git
    ireland
    Age is no real measure of a battery unfortunately, I would get the battery tested as DD has already suggested.
    Do you have a multimeter have you checked the battery voltage and the charging voltage ?
    Is it a std lead/acid battery is it topped up ?
    #3
