Bonneville Switched Power For Satnav?
Discussion in 'Bonneville' started by Sir Trev, Jul 12, 2017.
  1. Sir Trev
    Sir Trev Senior Member
    May 27, 2017
    667
    Buckinghamshire
    Hi all
    Looking to add my TomTom spaznav to my new T100. Any recommendations for a switched live in the headlight bezel I can run the cables to? I'd rather not run the leads under the tank to the battery.
  2. crispey
    Hi I got myself a couple of piggy back spade connectors and ran it off the horn on my tiger seems to be working ok
  3. pasher
    pasher Well-Known Member
    Sep 23, 2016
    138
    Nottingham
    Under the seat is a useless place for the USB connector imo but its assembly can be unplugged from the bike harness, so what I did was to unplug it, cut the cable then extend it to run under the tank and up to the instruments. The USB socket is now on a homemade bracket behind the fly screen, handy for the (in my case) iPhone holder.
    Photos here - https://www.thetriumphforum.com/threads/phone-holder-and-usb-move.9154/#post-107934
  4. Sir Trev
    May 27, 2017
    667
    Buckinghamshire
    Spot on Crispey. One piggy back spade on the switched live and a ring terminal on the bracket - the horn was a perfect place to get my power supply. No more charging for half a day in the car so I can use it on the bike - hoorah!
  5. big pete 68
    big pete 68 New Member
    Jan 27, 2017
    york
    Hi, I connected my sat nav to front side light in head light unit
  6. Sir Trev
    May 27, 2017
    667
    Buckinghamshire
    I wimped out of the sidelight option when I saw how cramped it was inside the bezel :no_mouth:
  7. RobH
    RobH Member
    May 2, 2019
    50
    Dunstable
    Re-using this thread rather than start a new one:
    Just picked up my 2017 T120 and bought a new TomTom 550 for it. I had assumed one should run wiring under the tank to the seat and use some feed off the fuse box. My question was, how does one get the cables under the tank? without taking it off!!
    But, if its ok to run the satnav off the horn 12v feed that sounds easier I guess? Anything to take note of in order to access the horn i.e. undoing the assembly on the handlebar etc?
