Bike Not Starting With New Fuel Connector 955i
Discussion in 'Triumph General Discussion' started by Garyg, May 24, 2017.
  1. Garyg
    Garyg Well-Known Member
    Mar 26, 2017
    Aberdeenshire
    Some help please bike wont start now ive changed the fuel connector that goes on to tank side . Noticed its leaking abit will this stop bike starting
  2. Sprinter
    Has it clicked home ? New o ring for leak (probably) Do you want fuel leaking on a started bike? Deal with leak first.
    Have you connected the rail the right way around?
    If I remember, you have a fuel connector each side of rail you could (maybe) put connector in wrong hole in tank, or connect wrong end of rail to hose, thus sending fuel wrong way into rail I did this and it wouldnt start.
  3. Garyg
    Mar 26, 2017
    Aberdeenshire
    It started. Yesterday but it might not have been leaking yesterday . Fitted everything today again and when bike wasent starting not even offering i noticed the fuel leaking and it was leaking on to the small cable that. You click in to the fuel tank that was soked ive ordered new conector from triumph plus new seals and fingers crossed this will be it .
  4. Garyg
    Mar 26, 2017
    Aberdeenshire
    Yes it clicked home
  5. Sprinter
    have you knicked the oring even a tiny bit?
  6. Garyg
    Mar 26, 2017
    Aberdeenshire
    Cant see anything but its been on and off a few times now today so going to change them the bike started fine after the ecu tune map then it wouldent start thats when wee noticed the fuel leak i mean it doesnt even try to start you would think theres no spark
  7. Sprinter
    Dont mean to be cheeky, have you checked kill switch, side stand ,clutch cut off ,is it priming , do you have lights instruments, If battery has not got enough charge then it wont try to turn it over.
  8. Garyg
    Mar 26, 2017
    Aberdeenshire
    Turning over fine fuel pump working everything working just not starting not even offering
  9. Garyg
    Mar 26, 2017
    Aberdeenshire
    I tried three diverant maps yesterday but couldent find the right one . Went out this morning started bike . But then died took it in to garage put her on charge then pnce charged tried starting then noticed the leak coming from the white fuel conector dripping on to the carpet then noticed it was dripping on to the electical cable coming from the fuel tank . Wont start at all
  10. ian
    ian Well-Known Member
    Aug 13, 2014
    22
    58
    From the mud people
    Please tell me you didn't order the plastic ones off triumph. They are notorious for breaking and most people replace with the metal ones you can get. Loads of threads about it and also wheres best to buy them. If you dont mind me asking, why did you have the tank off in the first place. You could have a kinked pipe or a pipe has popped off the filter inside the tank as you say you can hear it. Why the change of map also, have you added a pipe filter or done stuff?
  11. Garyg
    Mar 26, 2017
    Aberdeenshire
    metal ones fitted bikes going away to the doctor on monday mates going to check why its not starting
  12. Garyg
    Mar 26, 2017
    Aberdeenshire
    Ok lads bikes up and running after a hole week finding the problem . The new fuel conector i got from triumph that fits to tank was stuck the valve did not open for fuel to pass what a pain this has been soon as i got it un stuck the fuel lines presured up and fired in to life
  13. thebiglad
    Excellent news Gary, very pleased for you.
  14. Garyg
    Mar 26, 2017
    Aberdeenshire
    My head was bust before i found the problem lets you see never to trust new oem parts check before fitting from now onn
