Battery/starting issue
Discussion in 'Thunderbird' started by Richard Kaminski, Jun 15, 2016.
  1. Richard Kaminski
    Richard Kaminski New Member
    Jun 2, 2016
    London, Greater London
    Hello
    My recently purchased 02 Thunderbird 900 is having some starting problems and wondered if anyone could give some advice on diagnosing what the root cause is.
    Basically if the bike doesn't catch on the first press of the button, or it stalls from lack of choke, it will not restart. The engine turns over but incredibly slowly and just winds down to nothing.
    It happened once, I recharged the battery on a trickle charger and it then started easily. I noticed a couple of the cells were low on water (one only about half full, a couple of others are low)
    Few days down the line and same problem.
    I charged the battery again and tested with a multimeter, the charge was dropping as soon as it was off charge and dropped from 13 to 12.4 overnight, but I'm not sure what would be normal.
    So really I'm asking of a way to diagnose if it's a battery, regulator/rectifier or starter motor problem?
    Thanks very much in advance!
  2. thebiglad
    You've already done all the diagnosis necessary Richard, your battery is buggered and needs replacing.
    Just one final test before you splash the cash. Do this the next time she won't turn over with enthusiasm. If you got some decent jump leads, connect the bike's battery to your car battery (assuming you've got one) DO NOT RUN the car's engine, just connect to the battery. Once the two are connected, try firing up the bike. Does she fire up easily and quickly? If yes, your bike battery is finished and needs replacing.
  3. Richard Kaminski
    Jun 2, 2016
    Thanks Dave, I thought (hoped) that might be the case but wanted to be sure before buying a new battery as I can't afford to replace things in the hope that they are the issue!
  4. steve lovatt
    Buggered battery - exactly the same happened on my T100.
  5. thebiglad
    I'm with you on that Rich.
  6. Richard Kaminski
    Jun 2, 2016
    Out of interest, which aspect of what I have described tells you it's the battery?
    This is in no way to doubt your answer, I'm just interested in what symptoms mean what for future reference.
  7. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    Fact that you charged it and overnight it's dropped so far down.
    Shows it's not holding a charge. Hence battery knackered :D
    Wasn't so bad in the days of kick starts as the act of kick starting produced enough charge to turn the engine over.
  8. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    May I sugest the MotoBatt as a replacement, these have a higher than normal starting load which gives a slightly better tunrover when starting. I had no problems over winter and very reliable.
    The one recommended for your bike is the MBTX14AU - link
    Around £60 on Amazon
    Also liked by our friend Delboy - Garage link (Youtube)
    Best of luck
  9. Richard Kaminski
    Jun 2, 2016
    Thanks, I will have a look at that, was going to get a sealed one for around 40, is this one worth the extra?
  10. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    This is a sealed one, it comes with the Gel in pleace so no mucking round with acid
    I like this battery, it certainly has a more positive startup and I have had no problems.
    I would recommend reading the website to check all the differences and it is up to your judgement if you think the additional outlay is value for money.
  11. Sprinter
    #11 Sprinter, Jun 15, 2016
    the fact that it started fine the first time then not and if charged the same happened again is a give away.
    it charges up,only, not all the cells(perhaps only one cell and so looses charge really quickly.
    p.s. the Biglad is usually spot on about mechanics, and check Crispys previous threads for this,
    http://www.thetriumphforum.co.uk/threads/starting-problems-and-fixes.4913/
    starting proplem diagnostics,
    I have it printed out and keep a copy in the shed
  12. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    One good comment in there is about the copper slip. Planing on checking my break pads over the next couple of days. So just need to get some break cleaner now.
    Hopefully the pads are ok but as the bike has done less tan 4K they should be fine.
    Possible famous last words there :)
  13. thebiglad
    In fairness he said the battery was showing 13volts after charging - well it would IMMEDIATELY after charging, but within an hour normal behaviour would take it down to about 12.6v which you would call it's standing charge level.
  14. H.O.
    H.O. Noble Member
    Nov 28, 2015
    1,045
    ARDROSSAN, AYRSHIRE
    Only thing I miss about the Royal Enfields, they still had kick/start leg smacker levers, got a permanent bruise scar on the back of my leg to prove it!
