Auxiliary Power Supply 2002 Speed Triple
Discussion in 'Technical Help' started by DanielB, May 18, 2020.
  1. DanielB
    DanielB Noble Member
    Jan 13, 2019
    881
    393
    Abingdon, Oxfordshire
    Hi, not sure if this bike specific, so please redirect as required...
    On my 2002 speed triple 955i I have connected up a phone holder and 5v/2A usb charger.
    The usb has a tiny on/off switch...but... It is currently just connected direct to the battery ... Fine if I turn the usb off...not so if (when!) I forget.
    I know that i can/could connect the live to a switched live... But does it matter what?
    For example could I connect it to the side light - in the headlight? That only comes on with the ignition...or will I pop a fuse?
    Or just simply find any switched live in the loom and connect in to it?
    Any advice gratefully received - as always :grinning:
  2. Samsgrandad
    Samsgrandad Senior Member
    Dec 15, 2019
    577
    Somerset
    The draw from your charger is quite small, I would connect into the tail light or number plate light, both of these are ignition live and you can usually pick up the wires under the seat which makes it easier to connect into than in the headlight
  3. DanielB
    Jan 13, 2019
    881
    393
    excellent, that is this evenings little project. Thank you!!
  4. DanielB
    Jan 13, 2019
    881
    393
    All done! Spliced in to the numberplate light....all good!
    I even didn't fu#k it up! Bonus :blush:
  5. Samsgrandad
    Dec 15, 2019
    577
    Somerset
    Jolly good, job well done!!
  6. Vulpes
