A couple of problems with the Trident
Discussion in 'Technical Help' started by TOBY, Aug 24, 2013.
  1. TOBY
    TOBY New Member
    Aug 20, 2013
    9
    northumberland
    I have a Neutral light problem with my 95 Trident.It stops working when out on a run.Apparantly it's common on these and what I've read the only real fix is to split the cases
    The other problem is the Starter.It's working ok most of the time but then sometimes nothing.I can hear the Solinoid clicking and when I rock the bike in gear and back again to neutral it starts.
    This bike has only done 14,000 miles and so it's worth sorting but I don't want to do a complete strip of the engine.
    The Neutral switch,i've tried a couple of switches with no result.Apparantly their is a Aluminium earthing plate in the Box and so was told to fit the Switch without the washer but still the same.
    That's it don't know what else to do.No big deal living with the these faults but maybe someone know's something which will help....Cheers
  2. MICK64
    MICK64 Active Member
    Sep 15, 2020
    89
    NEW FOREST. ENGLAND
    Where is the nuetral switch, and how do i get to it please.
